I just received my new mini controller and unfortunately, I can’t find it in the drop-down menu of the settings and Ableton. I see the name in the input and output section, but not in the main section. That’s one issue that I’m having. The second issue is will I be able to program it where the button colors coordinate with the track colors in Ableton and automatically turn green when playing like the APC II does. Any direction would be great.
PS, I’m not very experienced. Thanks
Hello @jgrammatis!
Welcome to the forum!
In order for the controller to appear in the Control Surface section and to work as you expect with the track colors in the clips launcher section of your controller you need to use a remote script,
This is a piece of code for Ableton to be able to communicate with the controller and removing the necessity to map every time in each session,
Have you read the following forum post about Yaeltex Universal Remote Script?
Please take a look at the tutorial videos and let us know if you still have some doubts after that,
