I tried to compile the firmware with Arduino IDE on Linux but I got this error:
Bootloader file specified but missing: /home/lucian303/Desktop/ytx-controller/hardware/yaeltex/samd/bootloaders/zero\samd21_sam_ba.bin
I noticed the backslash which should be a forward slash on linux. So I changed the backslash to a forward slash in boards.txt and it compiled. But now I get this message (along w/ the .bin and other compiled files):
open /home/lucian303/Desktop/ytx-controller/hardware/yaeltex/samd/bootloaders/zero/samd21_sam_ba.hex: no such file or directory
Is this a problem or can I try to load the .bin file that was output with the firmware loader?
Also, is there a firmware loader or instructions for Linux or does loading the firmware only work on Win/Mac? Is there source for it that I could compile for Linux perhaps?
@francoytx Thanks. I’ll give it a shot with wine and if not, I can try a VM. I have a windows machine too in case all else fails. Do you think the error about the hex file is any concern or should it be fine to load the compiled .bin file?
And also the path has “bootloaders” in it, you are not compiling bootloaders.
Maybe it is looking for a bootloader to include it in the compiled binary, I will take a look and try to remove the warning.
The output binary file should be in the same folder that the .ino files
