Good day!
I configured my encoders to use rainbow coloring based on the value. However they appear to remain white. Is there something I am doing wrong? Would someone kindly highlight the docs section I might have missed if thats the case?
Hello @mnantel!
Welcome to our forum!
From your message I understand you are configuring your encoder rings with the Value to color feature.
If this is the case, then the reason they are white is because you haven’t received any messages that will change their color.
To use this feature, as it’s explained in Kilowhat’s manual you need to send MIDI messages on channel 16 (by default) with the value of the desired color.
In the case of encoders if the rotary is mapped to send CC #23 on channel 2, then to use value to color to change the ring’s color, you need to send CC# 23 on channel 16 (default).
Let me know if it’s clear enough or if you still need more help.
