Hi gang,
I need to order a power supply quickly as I have a gig this weekend and am having problems with my setup so I need to try using a power supply in case that helps avoid a crash during my set.
I know these are the given spec for the power supply: 5V / 3A / 2.0mm / center positive
But looking online there’s loads of other variables so I don’t know which one to order.
What should the Wattage be (I’m based in the UK)?
I have the largest of the 3 sizes of Yaeltex controller.
Can anyone send me a link to an example of the correct type of power supply so I know what I should be ordering? I’m not a very technical person…
Thanks for your help!!!
Suzybee
Bless you thankyou Ale!
Thanks so much for the link, thankfully i think that looks about the same as the one I ordered about an hour ago - i had to go for it tonight to get it in plenty of time for my gig: https://uk.rs-online.com/web/p/desktop-power-supplies/2047283
If the one I ordered is no good I’ll order the one you linked me to.
Thanks so much for your quick reply, it’s reassuring for me to know what specifications will be suitable!!
Yay! It’s great to know the one i ordered is good
We’re not live streaming but here’s a couple of links to recordings of my animations which I put together in case you want to see…
Animations for the Ocean: https://youtu.be/B8Yj2Caw11Q
Animations for the Earth: https://youtu.be/9Pgw-Dv7lw4
Also I’m not sure how but since I started using my Yaeltex controller I’m sure my visuals have improved!!
