Very noob question here.
I’m wanting to purchase a TR4MIX controller to DJ with. I noticed the TR4MIX does not have a headphones jack. How do I connect headphones to it?
Thank you!
Thank you!
These devices are “midi” controllers. All they do is allow you to control functions within a DAW, DJ software etc… You can’t connect a headphone jack to it as they do not create any sound. You connect the TR4MIX into a computer, tablet or any device with a soundcard etc… usually with a USB cable or midi cable. The audio should either come from the output of your computer or external soundcard connected to you computer. So, you would plug in your headphones into your computer, tablet or whatever it is you are using.
Best Regards.
Thank you so much for the clarification!
