Is it possible to use one set of buttons, to change the note range of another set of buttons?
See picture,
In blue, pressing the rectangular buttons would select the note range of the touch sensitive pads.
and or,
in green, holding that one rectangular button would act as a ‘shift’ button and then pressing the mini button and then the touch sensitive pad would assign the mini buttons note#, to that touch sensitive pad.
Are either and or both of these functions possible?
Its possible using banks. You can configure banks in Kilowhat (the app to configure the controllers). The number of banks (from 3 to 8) depends on the number of components on the controller. In the case above, you can have up to 8.
This one is not possible yet.
Please, be aware that the buttons are not velocity-sensitive.
