LEDs do not light up when I use it with VCV Rack2
The controller LEDs do not light up when I use it with VCV Rack2 (switch buttons and rotary controls). I can use VCV Rack without any problem and the controller works, but the LEDs do not light up. Does anyone know how to fix this?
Hey @daniel.dominguez93, welcome to the forum.
Make sure VCV is sending midi to the controller to light up those LEDs, this video might help.
Thank you for the reply. I’ve been doing some research and I think I’ve found the solution. There is a module called MIDI-CAT from Stoermelder that seems to do what I need. Will see. Thank you
