Live15 masterfader midi problem
Hi,
The masterfader on the live15has stopped sending midi. At first it was erratic, consistently sending out values. Yeterday I sprayed some contact cleaner in there. Today still emits erratic midi.
My next plan is to open the device up ans clean it manually but I figured I’d better ask for advice first. Thanks!
BR
Henjo
Hi Henjo,
Thanks for reaching out before opening it up!
I am very sorry to hear you are having an erratic fader :confused:
To help us diagnose this, we have a few questions first:
  • When did this start? Was it erratic from the moment you received it, or did it work correctly for a period before this began?
  • Was anything spilled on or near the fader?
  • What is the Live15 connected to? (DAW, hardware mixer, standalone setup, etc.)
  • Is the masterfader mapped to anything specific?
  • Is there any feedback going to that fader — either from software or hardware?
In the meantime, if you haven’t already, you can try a quick MIDI monitor test with nothing mapped and all MIDI apps closed:
Move the fader slowly through its full range and let us know what you see — random values while idle, erratic jumps during movement, dropouts, etc. A screenshot would be great if you can grab one.
Once we have the full picture we’ll know exactly how to proceed — and if the fader module does need replacing, your unit is under warranty so we’ve got you covered.
Thanks for the reply!
Heres the answers:
  1. worked out of the box, had a gig, then it stopped working the day after.
  2. some liquid came near the very left fader (channel 1) which started acting erraticly. I solved that issue with contact cleaner. No liquid came near the master fader, all the other faders are fine.
  3. Just Live / mac no hubs
  4. no
  5. not sure what you mean
Snoize midi monitor shows:
20:57:40.606 From LIVE15 Control 12 Hold 2 Pedal 118
20:57:40.616 From LIVE15 Control 12 Hold 2 Pedal 119
20:57:40.627 From LIVE15 Control 12 Hold 2 Pedal 120
20:57:40.640 From LIVE15 Control 12 Hold 2 Pedal 121
20:57:40.664 From LIVE15 Control 12 Hold 2 Pedal 122
20:57:40.664 From LIVE15 Control 12 Hold 2 Pedal 123
20:57:40.676 From LIVE15 Control 12 Hold 2 Pedal 124
20:57:40.687 From LIVE15 Control 12 Hold 2 Pedal 125
20:57:40.700 From LIVE15 Control 12 Hold 2 Pedal 126
20:57:40.717 From LIVE15 Control 12 Hold 2 Pedal 127
when fader at top it shows 127
when fader down it spits random midi between 20 and 60
Hello,
Please have a look at the details I posted per your request. Thanks
Hello Henjo,
Sorry for the delay on the answer, and thank you for the details.
To understand exactly what’s going on and figure out how to proceed, I’d like to jump on a short support call where we can look at it together.
I’ll send an email to arrange the call.
