Hello! I finally received my Yaeltex that I intend to use as a real-time fx controller for playing live, using Ableton.
I want to be able to use the joystick for different things, and change between these things on the fly. For example, having up/down be “FX1” and right/left be “FX2” and then switch them independently.
I started to play around with splitting the joystick in Kilowhat and then having each direction control a macro knob. That seemed like a good starting point but then I needed to make sure two Chains doesn’t make sound at the same time and then the Effect Rack starts to get a bit messy.
I imagine people in this forum has built similar setups? It would be great to hear how you did it!
Thank you in advance!
