Question mapping banks in Kilowhat and CSS
Ale! Thanks for the quick reply. I think I understood you.
  • In Kilowhat I changed the bank shifters to midi notes. :white_check_mark:
  • From Ableton/CSS I see the change between Modes :white_check_mark:
  • From Bank 2, I was able to make a play button using the same CC and CH. :white_check_mark:
My question now:
Is it okay to map buttons with identical cc and channel in the 2nd bank?
(I thought that when I changed banks, I had to use a different channel)
