Select Master Track with a button
Hi everyone. Second post from me.
My controller is setup 90% of the way and I want to configure a button to select my master track as well as some encoders to control a device within it. But it seems that in kilowhat this can only be done to select tracks (including returns).
How can I go about it?
For anyone interested I was able to do it with the Script and Kilowhat:
SELECT MASTER CHANNEL is parameter 117 / MIDI Ch: 1 in Kilowhat (0 in the script).
I’m having an issue now that even if the master is selected when I assign a button to SELECTED TRACK DEVICE ON OFF it’s turning ON OFF the first device on Return B (Even if the master is selected). Not sure how to circuvement this.
It should be parameter: 64 MIDI CH: 4 but it’s not working. Any help would be appreciated.
I’m glad you got the Select master track sorted.
Ok, something seems to be off. Let me take a look, and I will get back to you.
Hi Ale,
Thanks! I’ve reviewed and I’m using the latest version of the script. My device is called NYRA. Please find a screen recording link of how it looks within Ableton.
Screen Rec
