I’m trying to set the color of an encoder ring using Control Surface Studio…
I have figured out how to do it, but at a bug cost I’m not willing to pay. I’m hoping someone can help guide me to the light….
In CSS I used a Reaction to listen to a looper state and send a velocity value based on the state. I have a custom Yaeltex controller, which is set to receive encoder ring color changes on channel 16 (the parameter value is sent on channel 8).
The encoder is “hardwired” to channel 8 in the hardware configuration of CSS.
First, I tried switching the script view to “custom” and manually changing the channel from 8 to 16 in the Reaction code….which did nothing
Second, I created a “dummy” encoder in the hardware configuration, gave it the same CC number, but changed the channel to 16 and routed the Reaction Action to the dummy encoder. I was sooooo happy to see that this worked!!...when I changed the state of the looper, the encoder ring colors I wanted displayed…Yay! HOWEVER, what I found out is that by having that dummy encoder in the hardware configuration and script, it totally jacked up other aspect of my [stable] script (mode changes, LED colors, etc all acting up)
CSS gives me the option to send raw MIDI (sysex) to the controller, but I’m not able to find any documentation on how I would send an encoder “value to color” change using sysex.
From a Yaeltex Perspective, is there any way to determine the sysex for sending a color change to an encoder?
From a CSS perspective (if anyone here knows), is there any way to send parameter value (velocity) to the encoder on channel 8 and color value (velocity) to the encoder on channel 16?
