Yaeltex Universal Script - Device Parameters
I am putting together a bank where for the selected track, it allows me, with 16 encoders, to manage the parameters of the first 2 devices of the channel
As the following midi chart shows:
Selected Track Device Parameters ( midi chart - yaeltex universal script) :
Device 1 params: CC - midi channel 11 - midi message: 0-7
Device 2 params: CC -midi channel 11 - midi message: 8-15
Through this configuration the parameters of device 2 (8-15) although I have led feedback, by turning the encoders I cannot modify these values ​​from the ytx.
I looked at the map.py if any parameter could be modified but I did not find anything to modify.
Do you have any suggestion?
Thank you!
Andy
Hey @andinov!
You are on the right track. Double-check if your encoders are sending the right midi message using a midi monitor. Is the first device working?
The other parts of the script are working? Can we discard Ableton settings?
