Hi!!
Recently i updated to the 0.20 firmware but the update failed: the controller keeped doing the init loop (this flashy led rings rutine) again and again, did not respond to anything (even plugin/unpluggin it the loop restart again) so i used the midi cable trick to initiate bootloader mode and installed 0.16 firmware with he old uploader, Everything was fine again, but i really wanted the new features, so i tryed one more time.
In this ocasion i used the uploader option “erase eeprom” and repeated the process. this time, the updating process ended and the status led blinked 3 times and the unit turned off. Now every time i connect to the usb port, it does the same thing again, blinks and turns off.
What can I do now? I hope i dini’t break the unit, it’s quite expensive and I use it a lot.
Thanks!!
