Unboxing Your Controller: What's Included
The moment you’ve been waiting for has finally arrived! The journey from a design in the Factory to a physical instrument in your hands is complete. We know you’re excited to plug in and start creating.
This guide will walk you through what you’ll find in the box and your very first steps.
What’s in the Box
Inside the packaging, you will find two key items:
  • Your Custom Yaeltex Controller: The star of the show! Your unique design, handcrafted and tested in our workshop, ready for action.
  • A Custom-Fitted Soft Flight Case: To keep your instrument safe, every Yaeltex controller includes a beautiful and protective soft case, perfect for storage and transport to the studio or stage.
A Note on Cables
To keep electronic waste to a minimum and allow you to use your preferred cable lengths and types, please note that cables are not included.
  • For Computer Connection (Required): You will need a standard USB-C cable to connect your controller to your computer for power and MIDI communication.
  • For External Hardware (Optional): If you plan to connect to external synthesizers or drum machines, you will need TRS-MIDI DIN adapters or cables.
Ready to Go, Right Out of the Box
Your Yaeltex controller is designed to work immediately, with no complicated setup.
  • Plug-and-Play (Class Compliant): You do not need to install any special drivers. Your controller will be automatically recognized by Windows, macOS, Linux, iOS, and Android as a standard MIDI device.
  • Default Configuration Loaded: Your controller arrives with a default configuration already loaded onto its memory. This means that as soon as you plug it in, every button, fader, and knob is ready to send standard MIDI messages.
What’s Next? Time to Make It Your Own
While your controller works instantly, its true power is unlocked when you customize it to perfectly match your workflow. The pre-loaded default configuration is just a starting point.
Your next step is to use our powerful Kilowhat software to tell every component exactly what to do.
:right_arrow: **Ready to dive in? How to Configure Your Controller with Kilowhat: A Starter Guide
We are incredibly excited for you to begin your creative journey with your new instrument. We can’t wait to see what you create.
