Firmware version 0.21 released
Hey y’all!
Firmware version 0.21 is out today!
This is a minor update, mainly with fixes to a few issues that we have detected and corrected.
The most important of all being the fix to some annoying little noise on the 45mm faders, which appeared around 105-115 values.
To the users who came across this issue, we’ve been sending this fix individually,
On controllers of the last few batches, we’ve been applying it directly.
It’s a suggested update from v0.20, quite necessary moving forward if you haven’t yet updated to v0.20.
If this last case is your case, and you will jump from a firmware previous to 0.20, to 0.21, then please make sure to follow the steps 1-4 on the v0.20 release note.
v0.21
  • Solved fader noise issue.
  • Improved 100mm fader signal linearization and noise.
  • Fixed bug with inverted MIN and MAX with digitals.
  • Improved firmware and configuration versions control.
  • Improved analog filtering.
  • Freed some memory from analogs data no longer used.
  • Added possibility to configure individual components on the fly (without restarting) with sysex messages
  • Fixed issue with DEAD ZONE and Split mode on joysticks, not stopping at center value
  • Added 14 bit support for DEAD ZONE feature.
  • Fixed bug when something was placed after log faders that treated them as log as well.
